I agree with you that using 20W-50 seems like a desperate move, that is why I posted. I have been using 5w-30 Dino oil since I bought the car some 60K miles ago. I used Quaker state and Castrol and the oil consumption was the same for each brand. My oil change interval was 3000 miles for the last 60K and at each change I was using 24-30 oz. So when I switched to M1 I used 10W-30 thinking that would reduce the oil consumption, but no luck.Towncivilian wrote:Change your PCV valve (which might be causing your oil consumption). Use M1 High Mileage 5W-30 instead of M1 10W-30; high mileage oils contain stouter additive packages and seal conditioners to help slow or stop smaller leaks and reduce oil consumption.
Motorman my a**. 20W-50 is obsolete. It won't run cooler, since the engine's operating temperature is controlled by the cooling system. 20W-50 is excessively thick at startup and your fuel economy will diminish due to that fact; it'll take longer for the oil to heat up to operating temperature, and a 50 grade oil at operating temperature is still too thick for your M35 which specs 5W-30.
It's a shame we have to put catch cans on $50K vehicles - seems like an engine design issue. It seems not every M35 owner has this problem. What is different about their vehicle that they are not having this problem?jonlex99 wrote:I'm using Mobile 1 EP and changing it at 7k miles. Bottle says good up to 15k. I added a oil cach can and replaced the PCV valve as well will see what changes it made on my next oil change...
It's not that bad. I never had to add oil between change intervals. The oil catch can is just for piece of mind...thomasm35 wrote:It's a shame we have to put catch cans on $50K vehicles - seems like an engine design issue. It seems not every M35 owner has this problem. What is different about their vehicle that they are not having this problem?jonlex99 wrote:I'm using Mobile 1 EP and changing it at 7k miles. Bottle says good up to 15k. I added a oil cach can and replaced the PCV valve as well will see what changes it made on my next oil change...
antzrus wrote:I use M1 10w-30 from Costco. Once every 12k I change it. It eats about 1.5 quarts during that time. What's the big deal? By gawd I remember my old '56 Chev Belair all the way up to my last machine before the M a '91 Buick Regal sucking down all kinds of oil. My M runs like a champ-smooth as silk w/68k on her now.
Why the same 3k oil changes now almost 60 years later after the Belair and synthetic oil? It's 2012 now...
On mobil1 EP synthetic I go 7500 miles. I think what you may are geting at the dealer is conventional oil..M35SFIREMEDIC wrote:I talked to a guy last night that said with the synthic he goes for 7000 miles between oil changes. I change at about 4000. The sticker the dealer gives says change at 3700 miles. Has anyone gone as long as my buddy at 7k?
Correct. They generally use 5W-30 dino oil (my local dealer uses Quaker State) unless told to use synthetic ... for which they usually charge extra, of course.jonlex99 wrote:I think what you may are geting at the dealer is conventional oil..
Why? This is a complete waste of money. Synthetic may be "better", but is this really quantifiable at such a short oil change interval? For a naturally aspirated engine, I would not hesitate to say that any API SN rated conventional engine oil can stand up to Nissan / Infiniti's 3750 mile "severe service" interval given there are no significant mechanical issues (coolant leaks, air intake leaks, severe fuel dilution, etc).szh wrote:For me, it is Mobil 1 Synthetic 0W-40 and filter change every 3750 miles.
Consider it "overkill" on my part.Towncivilian wrote:Why? This is a complete waste of money. Synthetic may be "better", but is this really quantifiable at such a short oil change interval?szh wrote:For me, it is Mobil 1 Synthetic 0W-40 and filter change every 3750 miles.
Stock Nissan OEM. Have not found a good enough reason to consider changing to something else, I suppose.Towncivilian wrote: For a naturally aspirated engine, I would not hesitate to say that any API SN rated conventional engine oil can stand up to Nissan / Infiniti's 3750 mile "severe service" interval given there are no significant mechanical issues (coolant leaks, air intake leaks, severe fuel dilution, etc).
What oil filter do you use, out of curiosity?
Yes, it probably has to do with the quality of your right foot...thomasm35 wrote:Just changed the oil after 5K miles and oil consumption was at about a quart. I also changed the PCV half way in the interval.
Still wonder why some M35s don't consume oil and other do - is this a quality control issue?
Try it and let us know...thomasm35 wrote:Should I try the left?
