maxnix wrote:1.) Flush first, then drop pan and replace filter. Unless you have many miles and screen is dirty and pan is scummy, then do pan drop (and cleaning) and screen replacement first. You can get an indication by the color and condition of your present ATF. Browner is badder.
Hm. Dennis stated that cleaning and filter replacement should be done first. That's how they do at T3.
Quote »4.) Final flush with Mobil1, as that is the only way to replace the ATF. It is really not a flush but a fluid exchange.Depending on the machine, you need one gallon extra to flush. So 14 Qts.[/quote]
So, the fluid after the second flush remains in transmission?
Quote »Look for someone who has the Snap-On PS flush machine. If your fluid is in good shape, then a reservoir evacuation and fluid replacement while rotating the wheels lock to lock is sufficient. If it is brown, or you have leaks, then the hook-up to the high pressure line is required. More time and more money. A lot cheaper than replacing a rack. You will need 4 qts. of Mobil1 ATF.
Procedure for Pre 1995 t models and all a models is different as is the fluid quantities. [/quote]
Thank you, Brian
