But it may not be anecdotal if he actually measured it before and after. Might not have had sufficient controls to affirm 10° F difference, but still an interesting observation.PalmerWMD wrote:I think the temp drop is possible with the newer and better fluid but didnt expect it to be so large.Keep in mind this is anecdotal.
In reverse order, I note that a PS cooler was optional on the Z32, has anyone attempted to install one on a Q45? Both of my PS fluids (have yet to do the Y33) were only very slightly darker than new. Very difficult to tell using the white paper towel test.Q45tech wrote:So all in all what ever modifications keep the temp below 176-190F is the best............the coolant should not go above 195F and the oil in the pan above 210F [because the oil under the piston skirt/rings is 100F hotter.
Measure your diff conventional oil temp in Summer when towing and take a Valium.........why racers and even police cars have auxillary coolers for that also.
Ever notice that the PS fluid washes out the color faster than the ATF..........not enough cooling, small quanity, and massive fluid shear from the pump...........racks are cheap compared to transmissions or differentials.
What is a good premium differential oil?Quote » racks are cheap compared to transmissions or differentials. [/quote] In comparison, yes, but still not that low! I had a Q45 steering rack changed at a cost of $950 (for a new rack including the installation at the dealer, a refurbished one would have been $750). Fortunately, the extended warranty covered most of the cost. And, of course, a non-dealer install would probably be lower - what does T3 charge for this?Q45tech wrote:10F sounds about right as Mobil 1 engine oil will do the same for oil pan temperature........and a premium diff fluid will lower that unit even more.
elwesso wrote:I plan on putting mine in the active cooler location...... Thats just where I want it, I dont want to put it in between the rad and condenser.....
While the 70268 works fine, the 70264 would be better and has a higher cooling capacity.Q451990 wrote: I spent some time looking at that and couldn't come up with a good size cooler to work there.
If idling in city traffic in the Texas summer, I would consider the powered fan model. Haven't checked to see how it would fit. I think ducting is unnecessary in this location as there is plenty of air flow at even low speeds.Q451990 wrote: You also need an auxilary fan (already there in the other location) and ducting.
This location is much more simple on the later Q45 with twin OEM heat exchangers as the hose modifications are almost nil when retaining the OEM external filter and heat exchangers in the coolant path. If I hadn't seen how new the old fluid looked, I never would have considered this solution.Q451990 wrote: As much as I like the idea, the simplicity of the "normal" location won out - not to mention that it seems to work well there.
This is about a 30 minute job once one knows what needs to be done.Q451990 wrote: The way I do things, if it's going to take some time and enginering, it'll get put off, so the benefit of having it done earlier (and saving the transmission from heat sooner) was worth it.
An interesting idea! I'll have to look at an a model sometime. Maybe the service manual has a diagram.Q451990 wrote: I think finding a donor "A" car for the auxilary fan, brackets, and duct that runs from the bumper vent to the cooler, and then substituting a new transmission cooler of a similar size would be the best way to approach it. I'd love to see how it works!
elwesso wrote:
1)I plan on putting mine in the active cooler location...... Thats just where I want it, I dont want to put it in between the rad and condenser.....2)have the OEM filter still on, so Id assume its shot..........
The external filter was added to prevent particles from clogging the heat exchangers. Read the relevant TSB on cleaning the heat exchangers. The heat exchanger flushing procedure is not required for the G50 with the external ATF filter.__________________Brian1995 Q45 & Q45t & 2000 Q45elwesso wrote:So I guess Ill just rip the external filter out and forget about it.....
