Teknic73 wrote:just bought a case of M1 10/30. ideally this is proper weight for 70K right? or should i get some 5/30?
Since you are in California (correct?), for Mobil 1 either 10W-30 or 5W-30 will generally work quite fine, so don't worry about the case you just bought. However, my advice for the next case will be a different though!
Mobil 1 tends to run a bit thinner than other synthetics, according to an oil expert who occasionally posts here at NICO. So, I'd suggest a 40 weight Mobil 1 for the high end of the range for the next case! For example, I use Mobil 1 0W-40 with excellent results, although 10W-40 should be okay for summer months too. The only thing is that 0W-40 is not always easy to find at all place ... local Kragens have them though. The price is the same for all these Mobil 1 synthetics.
More importantly, do regular oil and filter changes, at most 3750 miles apart, and you will be fine with any good engine oil - synthetic or a good dino! I prefer synthetic myself, fwiw, of course! Just don't stretch the interval in the hope that synthetic gives you highly increased oil longevity - this is one of those "penny-wise-pound-foolish" issues!
If this is a 2003/2004 M45, then also check the oil regularly at 500 to 1000 mile intervals (cold engine, level ground, like right in the morning before driving) and replenish if the level is getting close to the low end of the dipstick. The VH45 engine, if not properly broken in, can consume some small amount oil in those intervals ... search for threads about "oil consumption" here in this forum to understand the concern. I do not yet know if this is an issue for the 2006 M35 or 2006 M45 engines ...
Z
