Not too many low riders in here sadly. I have lowered mine but nothing radical, just a nice sporty setup for cruising and autocrossing. Some peeps like to bag em, others go the static route. It's all up to you. But I have seen some frame laying static drops that will blow your mind. Probably handle like a** but they got a look all their own. The topic has been covered millions of times since the hardbody came out in 1986 so I say search and the answer is out there. How you go about it will depend on how you intend to use the truck.
If it helps the truck in my sig is running 2" blocks with a pulled overload leaf and turned torsions. It looks lower than it really is because the flares. I run wider tires and wheels for autoX so the flares help keep the tires from poking.
Handles good but required replacing the bushings all the way around, a rear sway bar and KYB monotube shocks. It may not be what you are wanting to do to yours, it's just running the set up up your were taking about in your first post.
Welcome to NICO BTW.
