DAEDALUS wrote:I used it to clean out my combustion chambers. I have to think it did a lot of good judging by the amount of crap that came out the pipe.
you know whats awesome, go to a mopar dealer and pick up some "mopar combustion chamber cleaner"
its foamy, what i do is pull the pcv hose to the intake manifold, and spray it directly into the hose with the motor idleing. works like a charm. also, if the carbons real heavy, ill let it soak overnight, then run it for a few minutes before i change the oil and plugs.
