nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Fri Jan 27, 2006 6:58 pm
Get a floor jack, or even better, a transmission jack.
It shouldn't be an issue, there are two other mounts, but to be safe, get a block of wood and put it on the floor jack and slide that up under the transmission, don't lift it up but have the block tight against the bottom of the transmission.
Or just use the aforementioned transmission jack.
The Nissan jack would work with a block in the same location, I suppose, but something more stable would be better in case you end up needing it (which, as I said, is doubtful).
Place it under the rectangular section of the transmission, probably has some ripples-ish in it. It's hard to explain without a picture, but once you get under there it should be obvious. It's the only flat spot of any decent size besides the oil pan, which would definitely be a bad idea, as well as in your way.
