MKIV Supre TT SMIC In An S13. Possible?
rico05
Car: 1992 RMS13 w/ CA18DET
I really want to run this for my initial install, but I am not sure about fitment. I have heard that some folks are running DSM SMICs, and since the JZA80 (MKIV Supra TT) is considered an upgrade for that IC, is there a way to get it in our cars? Thanks!
karay240
Yes, it's possible. But you will have to have cutom piping bent specifically for your application, and you may have to have it mounted as a front mount. If there's a will there's a way to use pretty much any junkyard intercooler.
sleighty
so, could you swap in a 2jza80tt into a 240sx????
s13sr20chris
i knew that was coming.
you sure can!
karay240
it's been done before. . . if you've got the money, anything's possible. lol
