also could use a wiring diagram to put it in my KA
not sure if i understand what ur asking, sorry im still stupid lolC-Kwik wrote:What are you planning to use to compensate for it?
Exactly, you would need supporting electronics for this idea to work.C-Kwik wrote:Well, just wiring up a new MAF is not going to work. The ECU will have no idea you are running a bigger MAF so it will inject the wrong amount of fuel. You need some way to fool the computer into injecting the right amount of fuel from the new MAF. Mass airflow sensors typically run in a range from 0-5 volts. 5 volts on a 240SX maf is not going to be the same airflow as 5 volts from a 300 ZX MAF or a MKIV MAF. And you only need to use a bigger MAF if you are exceeding it's capabilities.
