mixed up bearing caps
xavi_sir
Car: 240sx 91 K24ade
Hi, I was working on the engine head and my valve caps fell off without having a chance to mark them. I don't know if they are in the correct order, how I know where they belong. Thanks help greatly appreciated
wrong title ment valve caps
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
your going to hate this man...but you are going to play the puzzle game...first thing to do...put em all back in..then put the cams in..you are going to have to check valve lash each time..then remove the cam and try to fit the bucket in its best possible place to achieve valve lash requierments..the way i did it faster is to write on tope of them with a permanant marker the thickness of the shim on top of the bucket in (mm)..that way when i meshure the lash i can quickly see what shim will be closest to my factory spec...you will get the hang of it really fast..good luck man.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
I thought that they were all marked I1, I2 and E1, E2 ect.
youngun21a
Car: 240sx 1993 Automatic
mine are label like that too..
destroyyourmind
Car: 89 240sx hatch ka24de. 91 240sx hatch.
couldn't you use a caliper and measure everything?
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Why measure when you can read?
liquid_cool
the converted wrote:I thought that they were all marked I1, I2 and E1, E2 ect.
valve caps he said later on in his post..im assuming he means the buckets over the springs with the shim on top.
