Mistsubishi t25 turbo???
s14touge
Car: 1995 240sx s14
is it possible to use the t25 from a mitsubishi gsx eclipse on the ka24de. My freind sold me the turbo really cheap it has no shaft play and only 40,000 miles. Is it possible to use this turbo with the ka24de??
codyace
Car: S14 w/redtop
Pass on it.
Not the same....
ZX88
Car: s13
ive seen someone use a mitsu turbo on a ka not sure if it was an eclipse or a t25 though.
Tulsa_S-13
Car: 1991 SR 240sx
The mitsu turbo will have a different flange than the standard 4 bolt flange from say the SR T25.
IIRC, the Mitsu T25 also has a smaller A/R than the already small SR T25. So although it's possible to use the Mitsu turbo, it wouldn't reap the same awards. With low mileage and zero shaft play I'm willing to bet you could sell that and donate the cash to find a used T28 off an S14 SR.
I only say this because for a low power goal on the KA-T the T28 would make an awesome setup, especially for use in a low-spool autoX setup.
