mistergib »
https://forums.nicoclub.com/mistergib-u94032.html
Sat May 31, 2008 2:27 pm
ok...I'll try, but its difficult to get specific without showing you somepictures that I haven't taken yet...
...but, here goes...
First and foremost.....now think about this.....you will NOT be using your Garmin that much unless you NEVER know where you are going....mostof the time you don't need it, right? It's only used occassionally.That said, why then do you think you need to have it plugged in to yourpower socket all the time.....you really don't. The Garmin internal rechargeable battery lasts a really long time.....what I do is give it a full charge, disconnect the power wire (and store it in my console), use theGarmin for a long time, and then when the battery indicator on the screenshows the battery getting low, I just recharge it .....do this and you don'tneed that UGLY power wire slop'n up your dash.....imho.
Now, as far as the mounting, I used 1"wide industrial strength velcro fromHome Depot to secure the unit to my dash. It is very light, and the velcrois very strong so the unit doesn't move or vibrate or come loose, its verysecure and mounted there, the satelite reception is great. The mount that comes with the Garmin is a 2-piece mount, I only usethe piece that attaches to the unit, (it has the recharge socket). I apply the velcro to the curved rear of that half of the mount.
Thats all I do guys.....it works fine, stays secure, and looks clean....
