Missing wire connector/harness
JJM158
Car: 2007 Infiniti M35 S
my back center console panel with 12v outlet and rca outlets does not work so removed to find out am missing a connector, any clue on where can find other end? maybe rewire or add something new? Pictures below for details
https://imagizer.imageshack.com/img921/2553/ACoLpL.jpg
https://imagizer.imageshack.com/img921/3441/yZ7Yl3.jpg
https://imagizer.imageshack.com/img924/8675/tJMcmp.jpg
Ilya
You will likely need a donor car from the junk yard and pull that part of the harness. Probably will need the wiring schematics as well. This isn't a harness you can just buy...
JJM158
Ilya, do you own an M35 yourself or have had one, mines an 07 and was wondering how i can look up the missing connector/ wires? Unfortunately i am not near a junkyard to look for the part?
Ilya
I had an 07. You can start here:
https://www.nicoclub.com/FSM/M/2007_M45-M35/
You'll still need a parts car or to find a dismantler online...
macgiver
Looking at your photos , I mean you got 7 wires ? Do the colors match-up on the other side , or you know "what goes with what" - unless I'm missing something , wire nutting them ought to simply be your go-to
"Plan-B " ?? :bigthumb:
JJM158
i am missing the "other side of connector", idk why it would be removed, but maybe its hidden somewhere , will further investigate this problem, as the other end is not where it should be behind the armrest
