missing rb sensors and harness layout.... on 25/26 hybrid !!
StricNyne
ok wow, first off idk if i spelled interchangability right but ok !!seriously, i am gettin clase to crankin his mofo up, but i got some issues, i am missing
oil pressure sensor2 water temp sensors on my rb25det intake manifold
basically i need those, and if they are interchanagable with any other motor, i did search and i noticed MOST nissan motors use same pressure seensor !!
now on top of that, since i got a rb26 harness on a rb25, i cant just eye where each plug is supposed to go, i got a majority of it sorted, ie inj, ignition, maf, cas, but idk where a bunch of the other plugs lead to and its driving me nuts, i figure some go to the water temp sensor
plus i need to score a s14 lower harness and make that work, i am fabbing up all the power cables !
StricNyne
i got pics coming of all sensors, i realise i cannot id, the tps and some other things
Bluefire
Oil pressure sensors are all the same. If you happen to use a two prong one then you only need one of the pins. As for the water temp sensors, the single prong sensor should be matched with the chassis, and the two prong sensor is matched to the motor. I'm also thinking that a lot of the two prong nissan water sensors are the same as well, but don't quote me on that.
As for the rest of the harness, you should be able to find out what plugs are what by looking in the fsm. Just match the wire colors in the ecu diagram.
-Bluefire
StricNyne
good idea with using color, but it s all wrapped and prepped for a show quality car, so harness looks sick as hell, and i dont wanna tear up harness, pics will explain it a lot better
StricNyne
pics
skribblah
wtf??? 26 twins!?! why?
StricNyne
until i can afford the n1 turbos which will put me at 700 hp i coulda did it with a bing single but i wanna be one of a kind (GOD ITS A MASSIVE HEADACHE THOUGH!!!)
Bluefire
First pic looks like the plug for the resistor box... check continuity to injectors.
Second pic looks like one for the aac valve (blue plug) and the other ones maybe to the boost solenoid or maybe powersteering switch.
third pic has two water temp sensor, one single prong and one double prong. Also the double prong plug that uses a metal clip is for the intake air temp sensor
fifth pic looks to be for throttle position sensor and throttle valve switch
Also the rb26 doesn't have VCT.
As for the fuel lines the longer one with the curved end should be the return
-Bluefire
StricNyne
ok i have rb25 inj so i dont need that resistor box, and since i am using the rb25 aac, mine has 2 plugs so that fixxed that, i am going to plug in everything and take more pics of the unknown !!, also stupid rb25 coil packs use slightly larger plug, so i gotta splice in my rb25 ones, so that means INJ and Coilpacks need their plugs replaced
240z4u
Car: '95 Nissan 240SX
Don't take this as an insult, but how did you build such a nice looking harness with no motor to use as a reference?
Evan
StricNyne
i didnt build it !! Scott Buwalda did and its god like !! hehe it seems like everytime i make progress the hill gets larger lol, i wish i kept my stock rb25 harness, and kept my power fc i woulda been running maybe 2 years ago
http://www.kouki.co.uk/Reference/rbpinout.asp found that pinout too
StricNyne
this will activate the VCT http://www.shopatron.com/produ...424.0
Modified by StricNyne at 5:54 PM 3/5/2008
gawdzilla
Car: none
this thread is headed nowhere. few suggestions1) don't assume things will work because you can plug them in. nissan shares a lot of plugs.2) you need to bypass the resistor box wiring whenever you identify the plug. can't just leave it unplugged or you'll have an open circuit.3) USE THE FSM and a continuity tester. figure out what plugs are what by tracing them back to the main plug on the ecu.4) 700hp isn't coming from the n1's
StricNyne
meh not assuming thats what everyone is telling me, and what i am reading everywhere, just i know some plugs are in differant locations like rb25 tps and rb26 tps are in dif locations thats why it s apain in the ***, the rb25 has a **** laod of harness information but stuff for the rb26 is very scarce, im gunna use the suggestion of getting color and matching it up from the ecu pinout, as far as the resistor box goes i could patch them togeather, but liek i said i havent seen a decent wiring diagram for the rb26 i got the aussie fsm and it sucks for rb26
StricNyne
n1 turbos http://phase2motorsports.store....html
they are 2871r which in single application have made 370 with cams !!
gawdzilla
Car: none
not really sure what kind of information you're looking for on the internets there, but all you need is the r32 or r33 FSM. i don't think you'll be flipping to a page titled "stricnyne's rb25/26 hybrid tt motor swap using rb26 harness" in the fsm if thats what you're looking for.
you need the main wiring diagram that shows all the sensors and how they go back to the main plug. then you need the diagram of the main plug. that is enough information to figure out what each of those plugs you have pictured are.
post up yours or anyone's 700 hp dyno with those n1s as twins plz
StricNyne
i was looking for an idea where the sensors are since i never owned a rb26 heh, and it has stuff that i dont have nor need, like the air intake temp sensor, i looked at fsm and the diagram i has SUX it doesent show me where plugs go or where they need to be, combined with that pinout i and a continuity test i got SOMETHNG to work off of, but not ez at all, imma find that dyno for u
Bluefire
N1 will not net you 700 hp. A friend of mine just had his fully built R34 GTR with twin GTRS turbos tuned and it made a little over 700hp with C16 at about 1.6 bar. You really have to stroke the motor and run race gas to hit 700+ hp....
