Missing Parts w/ Walbro Pump??
vboyq
Can someone tell me what should come with the Walbro Pumps for the SR in a 91 240 sx. it seems as though i don't have everything that is in the directions( there are pics of pieces that didn't come in my kit)?
thanks people
robbbby
This is what I remember off hand since it has been along time since I changed mine.
PumpFilterHarness with connectorsLittle black rubber piece to hold it on the baseCouple little washers
vboyq
i read a post before about someone suggesting that i get a new gasket from the nissan, does anyone know what gasket they are talking about?here's the link:http://www.nissaninfiniticlub....stall
vboyq
oh whoops would seem that came from the RB forum.. does that matter? would i still need one?
robbbby
I changed the gasket between the tank and the assembly that holds the fuel pump. It's just a big round o-ring. It is to stretched to reuse usually.
vboyq
thats for the 240sx 89-94 gas tank right?
vboyq
anyone have a part number for that?
180fan
Car: 89 fastback
it's just the sender unit o-ring. bought mine for $7.15 since mine was like what 15 years old and over time it streched out. The new one works much better. BTW you're supposed to replace that each time you open the sucker up, although I never did until I overhauled all the hoses and seals in my fuel system. I'll look over my reciepts and find the part number, but I won't be able to get to it for a couple days.
vboyq
well either a part number or what i tell the dealership specifically to get that piece. you did get them at dealrships right? if not then where did u pick urs up, gotta get this right the first time dont have any room for mistakes! thanks guys
180fan
Car: 89 fastback
I got mine from dealership. Also there is just one o-ring at the fuel sender unit. If you get it dealership, they should know what you're talking about. Mine had them in stock. Oh lucky you, I just found the parts sheet for the s13's fuel system. Part number is 17342-01A00 and cost me $7.15.
vboyq
thanx man i appreciate it!
UsedToOwn240SX
Car: Radio Control Racing, Counterstrike
Just cut the o-ring a bit at a time and fit it back. Don't cut too much! That's what I did. That o-ring will swell up once you take the pump assembly off.
