240drfter »
https://forums.nicoclub.com/240drfter-u102266.html
Sun Mar 29, 2009 5:04 pm
bump. went out checked it all over again 150psi on cylinders,injectors 12v, coil packs 12v, coil sparks injector fires.......could the cas separate the time that the injector fires from the spark cause it still soaks plug so i know its firing, but i was wondering if it could be firing at wrong time. also is there anything i can get to check voltage of spark. trying to get this solved before big turbo upgrade.
