Missing hold down wiring clamp
Big Dawg1
Does anyone know where I can find this hold down clamp.
After having the car worked on, this clamp was lost.
BM
engine bay.jpg (24.04 KiB) Viewed 798 times
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Those are just regular rubberized pipe supports. You can get them at Lowes or Home Depot and drill out the screw hole to enlarge it if necessary.
https://www.lowes.com/pd/Hillman-2-Pack ... mp/3342766
Big Dawg1
Thanks for the tip.
It looks the same, however, since I go to ZCON each year and enter their Concourse Judging, I want to ensure that this is the same part used by Nissan on the Z32 NA (1990-1996). Otherwise, points will be deducted from my judge sheet.
Any thoughts?
VStar650CL
Technical Expert
From the parts drawings it looks like it might be a 24210-50M01, but I can't find any photos and it shows discontinued. You might just want to scale the photo to get approximate measurements and find something with the same approximate width and diameter, or maybe measure one directly off a different car. If it looks identical I'm not sure how even a concours judge would find nits to pick, and I'm sure Nissan didn't make the original part themselves, they bought it from somebody.
Big Dawg1
Thanks again for the help.
At least I now have the part number.
So the search continues.....!
