First Ride »
https://forums.nicoclub.com/first-ride-u302629.html
Thu Jul 29, 2021 9:11 am
Hi there, I just got a 1984 720 from my uncle for my daughters first vehicle and I need a little help. It was in a shed for the last couple years and some thieves came in stole the battery, cut a cable (3 wires - white black and green) and took the component it was attached to. The wire is a 3 strand cable that was cut close to the battery and runs to the rubber grommet under the passenger seat and then up under the dash. There is a connector on the inner fender with a plastic cover where at least one component was but I have no idea if that is the only thing missing.
Does anyone have wiring diagrams I could look at / advise to give? I went to a local junk yard that had a 1987 truck and grabbed the component from the same part of the truck (it had the same plastic shroud and 3 wires (all green with different markings) but I have no idea if it is compatible or not.
Thanks for any help you can give me,
Bruce
