Missing bushings and bolt front differential/engine???
smitchell4888
Car: 2011 Infiniti M37x
Hopefully the link for the image works
Was under my 2011 M37x yesterday and noticed what I initially thought was a missing bolt joining the front diff to the upper oil pan. While trying to find the part(bolt size/thread pitch) I think I found out there's actually suppose to be two bushings AND a bolt there. One bushing between the diff and block, one bushing between the diff and bolt, then the bolt
Is that correct?
Thanks in advance
How would one even go about fixing this without doing a drastic amount of work as I have fairly limited resources and funds atm.
I can only guess the engine or diff got pulled at some point and these items never made it back where they belong
smitchell4888
Reason: Fix Links
smitchell4888
A short video trying to give people some idea where this is but it's super tight under there so its a little difficult
smitchell4888
schematic for the front diff linked below, the bushings I'm speaking of are 38210F/part#12307-0P00A the bolt being 081A1-0351A
anyone else agree/disagree?
https://www.infinitipartsdeal.com/page_ ... rtNumbers=
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Just a friendly note. Cross-posting (i.e. posting the same message in more than one forum board) is frowned upon. It's confusing and often counterproductive. Please choose the forum topic that is closest to your post, and place it there only. If you should create a post in one forum, and later realize it would be more appropriate in another forum, please delete the original before posting it again.
Duplicate topic deleted.
smitchell4888
would have preferred it stay on the g37 board, more popular platform would probably get more traction but thank you
