240life wrote:Are you sure you have no boost leaks? I had rebuilt my Sr and it was idling great at warm up but after a minute it would stall... while driving it would boost fine, but at idle it would be all up and down.....bouncing between 100 and 900 rpm and stall if I wouldn't keep my eye on the tach. All as it was, and I had checked was a coupler not sitting right creating a boost leak. So even though everything was tight and looked good to the eye..it was not. I reseated all of my clamps and now everything is 100%. I hope you figure this out soon, good luck.
thanks for the advice, in answer to your question, i checked for boost leaks, and so did the shop that tried to fix my car. i couldn't find any leaks in the intercooler piping, but alot of air was coming out of the PCV hose. (the one that comes from the "T" fitting on the valve cover). not really sure if that is normal.
this is what i have done so far...
-No codes on ECU-replaced TPS (bad)-replaced MAF (bad)-replaced injectors (370's)-replaced ecu -replaced coolant temp sensor -replaced spark plugs (ngk iridium)-replaced fuel pump (walbro)-replaced injectors (440's)-checked for boost leaks-checked for vaccum leaks-checked wiring harness (pulled apart, looked good, but did not replace)-checked vaccum hoses (correct hookup locations)-checked timing-checked grounds-checked alternator-checkes fuel pressure regulator-checked timing chain (just top two timing marks, not bottom)-checked power and grounds on ecu plug -checked Greedy Bov (closed all the way)-checked turbo (for runout/ missing teeth)-checked compression (150psi x4)-re-checked ecu (good)-re-checked maf (good)-checked coil packs-checked coil pack harness-checked ignitor-checked to make sure all cylinders are fireing-checked to make sure all cylinders getting fuel-installed and tuned Apex-i Power FC L-jetro -installed Power FC D-Jetro (no more maf)
**here are the symptoms i still have**
-lopey idle (very very rough, whole car shakes, it actually broke one of my new autometer gages)-missing at idle-low boost 5psi max-low vacuum-almost stalls after revving-lack of power
