Missfireing RB26
89 GTR R32
Car: 1989 Nissan Skyline GTR R32
My R32 is missfireing every now and then. Manly when I get down on it a little and come to a cmoplete stop. It does not sound like it is doing it very bad, but enough that I can tell. The guy I purchased it off of said he put brand new coils and all on it and I believe him because the car came with all the old coil packs and other ignition crap. I was maybe thinking that maybe one of the coil packs that he got was just bad from the start, but what do I know. Just asking for any ideas on what you guys think it might be (I don't have any expereance with RBs). Thanks.
Joe
misfire on decel?
totally normal. thats why RB's kickass. you should hear the sounds that come out of my car after a session.
rbosacco
Car: 97 discovery1, 99 yukon, 97 240 rb26 in progress, 72 280se benz 4.5, 03 gti, 98 vr jetta chump car, 91 straight axle 2500 suburban, 00 f350 super duty crew cab 4wd, v70 volvo wagon and a built warrior
what is your misfire like? my car has developed a slight one at part throttle, i mean, when it does it it is a dead miss and i'm kinda wondering if my cas is acting up....
89 GTR R32
It kind of sputters a little, like it is kind of fluding it self a little.
Ramius83
Car: 1995 240sx SE
You are saying that it is sounding like it is mis-firing at idle? Kind of, like, sputtering a little, but only does it like every 10-15 seconds or so? If so, then it is most likely a leaking injector. Very common with older engines. Now, new injector o-rings will not solve this problem. It is the actual injector leaking through the pintle cap. Only solution is to buy new, larger injectors and a Power-FC....
