Foosblood24 wrote:Hi, I'm new to the forum having recently purchased a 93 NA 5sp and you guys seemed very knowledgeable about stuff.
I'm experiencing a misfire in at least one cylinder. I've changed the plugs and one coil pack but the misfire is still occurring. I don't want to swap out the rest of the coils if I don't have to. Is there a way to test the coils to see if they're bad?
No it's a 93 which does take a different injector but does that make a difference in fail rate or do the injectors fail for the same reason?ThisIsSparTTa wrote: You have a 92, which means you likely have old style fuel injectors
Advice taken and understood. The customer service rep did say the phase 2's were remans, and the phase 1's were new. Both have a 2 yr warranty but all the trouble it seems to take to do the phase 2's seems extensive. But if the phase 1's are new (and it's what I'm currently running in the first place) I'll have to go with that.RubyRed300ZX wrote:Beware: Those prices seem too low for new injectors. And, nowhere on the page does it state "New" or "re-manufactured."
The cost of the labor to install the injectors (or your time to do so) isn't worth the savings for re-manufactured injectors. Typically, re-manufactured means they clean them, and replace the o-rings. Does nothing for the tired solenoids.
Her hand is usually already preoccupied with pretending to drive a "British-side" manual transmission.RubyRed300ZX wrote:As for a cup holder on a 300ZX, that's what curvacious blondes are for when they're strapped into your passenger seat.
Ah...that's interesting. They actually made a different fuel injector based on the convertible top?nissanfreak12 wrote:CV means convertable.
Just go check the connectors, that is the best way to tell.
Lovin' that right there! Phase 2 it is!nissanfreak12 wrote:Phase two have a better spray pattern, can handle ethanol, and are the same price minus the install kit. I switched over to phase 2, much better idle, throttle response, and definitely a good peace of mind.
Don't get me wrong, I'm just very analytical on stuff (drives my gf batsh*t too) I just like to explore all the options. I'm definitely taking your advice, believe me!nissanfreak12 wrote:Quit questioning it and get phase two, there has been multiple discussions about this topic.
It is always good to ask questions. Nothing wrong at all.Foosblood24 wrote:Don't get me wrong, I'm just very analytical on stuff (drives my gf batsh*t too) I just like to explore all the options. I'm definitely taking your advice, believe me!
nexus08 wrote:It is always good to ask questions. Nothing wrong at all.Foosblood24 wrote:Don't get me wrong, I'm just very analytical on stuff (drives my gf batsh*t too) I just like to explore all the options. I'm definitely taking your advice, believe me!
I had not heard that the Phase 2 had better performance (other than the ethanol issue). That really helps with the sell.
My thing is, I have an NA T-top. (Lord knows why there's a fuel injector difference between T-tops and convertibles...) but that's what I have. My biggest question is do I even need the adaptors for the phase 2's?ThisIsSparTTa wrote:You shouldn't require a new fuel rail in either case. The adapter kit works perfectly fine for adapting the new injector to the old fuel rail: http://conceptzperformance.com/Cart/des ... .164.62.64 .
What is a water line bypass? I'm guessing the EGR delete has to do with the chip?ThisIsSparTTa wrote:TBH, I don't know that the Dremel method is the best time saver. You're going to tear up some bits, and that damn plenum grind for #1 that you to do regardless was a b**** for me even with the plenum off. Also consider that the dremel method gets metal shavings everywhere.
I'd recommend a plenum pull with a water line bypass and EGR delete if you can get away with it where you live. They aren't that scary after the first time, and they can go really quick. You can also get happy and replace the intake valve cover gaskets while you're there as a cheap form of insurance against headaches in the future, they are easy and quick. I wouldn't recommend doing exhaust valve covers with engine in unless they're leaking. Total PITA.
