tucker3113 »
https://forums.nicoclub.com/tucker3113-u53514.html
Tue Oct 23, 2007 8:32 am
It is a brand new plx wideband setup. The new o2 sensor is what is ran to my ecu to replace the stock original sensor. There are no vacume leaks my vacume at idle is around 18 and the timing has been an issue since the lowend missfire is giving problems with setting the timing. My main question is more or less has anyone seen a missfire create overly lean a/f ratios on there car.
