miss firing! please help on my 96 240sx
benjie
Car: 97 240sx
what's the possible caused of miss firing engine? check engine light went on and starting to hesitate when i step on the gas, it's not responding, strugling to accelerate, and i got it dianosed, few codes came out, knock sensor, miss firing cyl#4, evaporator, and something else, what could be the possible problem, please reply if had the same problem thanks
sdtouge
Car: 1990 240sx coupe
all the things that came up when you got it testedcheck your knock sensor, check your spark plugs and wires, and i dont know what your evaporator is.
the diagnostic says what is wrong with your car, so whatever it says is what it probably is.
240sx2nr
Car: 95' 240sx zenki
did u check the injector on cylinder 4 thats causing a misfire? that could be a problem.... and the diagnostic does say whats wrong with your car, but it doesnt say why the part went bad...
