PulsarDet »
https://forums.nicoclub.com/pulsardet-u30679.html
Fri Nov 04, 2005 3:31 pm
I guy's I have a big issue and I am not able to source the problem, the car is miss firing between 1.5k and 3k, if the car is on boost the car run fine, if not on boost the car has some serious driveability, I check all the sensor they are all connected, check ecu for code, their is no code at all, I change the maf cause i got one spare, nothing has changed. The car don't burn any oil or prestone.
Any idea ?
The last time I took the car was running strong and no prob at all. Just appeir during the night .
The problem append when the car is cold or hot. It just doesn't matter, I change the igniter in case but still no fix.
Modified by PulsarDet at 6:20 PM 11/4/2005
