Another tip. Don't use Nismo engine mounts, they raise the car a little bit, so OEM fan hits the shroud sometimes. I noticed a small groove inside of shroud.OM3GA wrote:It definitely fits, i have installed the stock fan and shroud (best cooling setup) on 10 cars. The one thing to be careful of is that you need to retain an OEM designed fan clutch, a lot of OE replacements are a little thicker which pushes the fan closer to the shroud and makes it hit since the clearance is already less with the thicker radiator. You can get away with OEM or Beck Arnley for fan clutches.
