Mishimoto Aluminum Radiators!!
FREE OVERNIGHT SHIPPING This high quality radiator is an inexpensive alternative to the higher priced items with equal if not better cooling!
Packages:
Mishimoto Cooling Package for the KAMSRP: $705.00Normal Price: $522.50Special Price:Call or E-mail Me!!!!-Radiator-Fans-Thermostat-Cooling panel
Mishimoto Cooling Package for the SRMSRP: $840.00Normal Price: $603.50Special Price:Call or E-mail Me!!!!Includes:-Radiator-Fans-Thermostat-Hoses-Cooling panel
Mishimoto Aluminum Radiator for Nissan 240sx S13 and s14 - SR20 or KAThe Mishimoto performance aluminum radiator for the Nissan 240SX is designed and engineered to maximize cooling efficiency by up to 30%, boost engine functions, and most importantly protect your car from overheating. Whether you drive your vehicle daily or take it for track runs. The Mishimoto aluminum Nissan 240SX radiator features a lightweight dual core, 100% brazed aluminum, and polished end tanks, enhancing the overall performance of your engine. Every Mishimoto aluminum radiator is a direct OEM fit, making installation effortless with no cutting or modification required, the ideal upgrade to the stock Nissan 240SX radiator. All Mishimoto radiators come with a high pressure 1.3 bar Mishimoto radiator cap and a 'no questions asked' warranty including accident protection. For even more cooling efficiency check out the S13 fan shroud kit."]Specs on this awesome radiator
Overall Size: 26.4" x 19.5" x 3.8"Core Size: 14.13" x 25.12"Rows: 2Inlet: 1.25"Outlet: 1.25"Core Thickness: 1.97"Tank Wall Thickness: .08"Fill Neck: 1.25"Drain Plug Thread Size: (M16) .06"Drain Plug Thread Length: .047"MSRP: $300.00Normal price: $225.00
Mishimoto Radiator Fan Shroud for Nissan 240sx S13 and s14 - SR or KAThe Mishimoto 1989-1994 Nissan 240SX S13 fan shroud kit is the perfect match for our radiators. The Mishimoto fan shrouds are made for a direct OEM fit and include two 10 inch Mishimoto electric fans.All Mishimoto fan shrouds are significantly lighter and more durable than OEM fan shrouds and will notably improve engine cooling performance by delivering a significant amount of cooler air directly to the S13 radiator. The Mishimoto fan shroud kits also safely secure the fan blades from any potential damage to other essential engine components.Includes:Aluminum Shroud(2) 12" Slim Electric FanOverall Size:Height - 16.8"Length - 26"Width - 2.5" (including fans)Mounting Hardware(8) M6X20 Screws(4) M6X16 Screws(8) M6 Nuts(10) M6 Plain Cushions and Elastic Cushions(12) M6 Nuts, Plain Cushions, and Elastic CushionsMSRP: $265.00Price: $185.50
Mishimoto Radiator Hoses for Nissan Silvia SR20DETMishimoto silicone Nissan 240sx radiator hose kits are made with a dual layer combining high grade silicone and heat-resistant embedded fibers to provide efficient heat reduction and increased pressure tolerance, all with an OEM replacement fit! Perfect for your Nissan 240SX
Interior Material: Heat-Resistant Embedded FibersExterior Material: SiliconeMax Temperature: 330 F
Inner DiameterHose 1: 1.3"Hose 2: 1.4"Outer DiameterHose 1: 1.65"Hose 2: 1.73"MSRP: $135.00Price: $81.00
Mishimoto Racing Thermostat for Nissan 240sx SR20/KA24The Mishimoto racing thermostat for the 1989-1998 Nissan 240SX will promote greater cooling efficiency throughout your engine. The Mishimoto racing thermostat will significantly lower high engine temperature produced by modified and upgraded turbo applications. Once the engine is fully warmed up the Mishimoto racing thermostat will open up at a lower temperature than standard thermostats, also allowing the coolant to flow through the engine sooner thus reducing and maintaining cooler engine temperatures.
Mishimoto Thermostat Activates at 60º COEM Thermostat Activates at 76.5º CMSRP: $60.00Price: $48.00
Mishimoto Air Diversion Panel for Nissan 240sx S13 and s14The Mishimoto Nissan 240SX Air Diversion Plate is not only intended to enhance the aesthetic appeal of your engine, but will incomparably reduce your radiator’s coolant temperature. All Mishimoto air diversion plates are constructed of 5052 aluminum and are available in several finishes. Choose from a natural brushed matte or an anodized glossy black or blue to enhance the look and style of your Nissan's engine bay.MSRP: $80.00Price: $64.00
For any questions or to order, call, e-mail or IM me!!E-mail:
[email protected]: 203-783-1422 ext. 113AIM: CIPJohnB
Modified by
[email protected] at 9:38 AM 5/22/2009
Modified by
[email protected] at 5:21 PM 6/5/2009
