afracer wrote:Do you have a wideband O2 sensor? Check your a/f ratio under full boost...sounds like detonation/running lean.
No I don't have a wideband...yet. But every once in a while I get a pretty good, embarrassing backfire, so I'm pretty sure I'm not leaning out.
ILikeMy240sx wrote:Do you remember what type of plug it was? i.e, what manufacturer, what material, what heat range, and what gap?
I'm pretty sure they're NGK Iridium, but the gap is whatever the manufacturer set them for the '91 SE-R. I never had a problem until now with that...
Is .028" the ideal gap for the SR?
