Well I have been breaking in my KA-T for a few months now and have a persistent misfiring issue. When at idle or light throttle the car surges slightly , like one cylinder is dropping off. Plus im getting a missfire code (duh) and gun-shot-like backfire when decelerating in gear. When I try to accelerate there is a also lag for a few seconds right off of idle then power comes on strong. The boost/vac does not change while this is happening so I do not believe it to be turbo lag.
Each time I pull the plugs cylinder three is way rich (black). After speaking with a technician at Garage Kwai, he suggested that the problem may lie with the ignition system. I confirmed this with a timing light on cylinder three and observed the light blinking intermittently to not at all at idle. If I rev the engine fast the light blinks normally but starts blinking intermittently after returning to idle. I tried swapping the distributor with the one from my '96 KA. After warm up, I still had the same problem. So I swapped caps back, which resulted in the same problem.
Origonally I was told that this was most likely due to a leaky injector, so I did the injector drop test and #3 has no change in roughness when that injector is unplugged. Which makes sense to me since if there is fuel going to that cylinder it is not being ignited anyway.
So I ask yall, does the problem lie with the ignition (New distributor to the tune of $500) or is the injector pissing so much fuel out the rail that it is fouling the plugs and not causing it to fire? Each time I pull the plugs I clean em with a wire brush to get rid of the carbon crap.
By the way I have new plugs (BKR7E gapped to 32) and new wires. The injectors are nissan 370cc/min cleaned and inspected by RC Engineering.For reference here is my previous post and complete setup:
http://www.ka-t.org/forums/viewtopic.php?t=4249
