180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon Nov 27, 2006 2:35 pm
first off, check what was damaged. if the cylinder walls are damaged, go find a bare block for the cheapest fix. machining for sleeves and the sleeves gets expensive. why bother with another long block? you've already got everything else you need, just get either a shortblock or get the block. if your pistons have gone toast, get oem replacements. significantly cheaper than aftermarket forged pistons and if you're only shooting for 300-400, they'll do that all day long if they're new and put in properly. coil packs are cheap and can be found used easily. spark plugs, you should put in new ones every so often anyway. headgasket yes.
