Think i found the problem.
I recently installed Megan turbo exhaust and took out the temperature sensor since the exhaust doesn't have the O2 bung for it. It hasn't been welded back in the exhaust yet.
Is it neccesary to put it back in? I assume yes because it might be screwing up fuel delivery.
r34 gtr wrote:its gotta have something to do with the ecu's open/closed loop control. i would check the 02 and maf, but it could also be something like a coolant temp sensor. try swapping the ecu out to if you can, its worth a shot.
- tim
