Lopin18 »
https://forums.nicoclub.com/lopin18-u58480.html
Sat Aug 02, 2008 6:18 pm
HEEELPPP!!!!
Changed Fuel pump, fuel filter, Fuel lines, no leaks, and still misfiring around 5000 rpms....
Things i noticed:-Fuel pump 15Amp fuse is melting slowly-Key assembly is hot, cables also (I rewired the ignition Red/Black cable that goes to ignition coil, fuel pump fuse, ecu, etc... rewired where it was melting in hope to fix my problem but its still getting hot but not melting like before)-After like 2 hours of cruising the car started shutting down every 15 mins, had to let it cool like 30 secs before he would start again.....
Soooo plz.... any tips?? tomorrow im changing spark plugs, but that fuel pump melting and hot key assembly+cable is still a mistery to me.....
Tips, Help, Guides, plz im really desperate ive tryed a lot of things already :S
