JDMSIL80 wrote:Yah the ARC is causing too much problem when venting, misfiring or cut out all over the place.
Im actually planning to get the HKS SSQV as well, together with the adaptor that allows me to recirculate.
So you are able to vent the HKS without any problem? I notice the SSQV has changed to new design that is no longer adjustable, don't know if this is necessary in my case.
I thought about going with the HKS Racing Type II BOV, but it seems too aggressive on a CA since it can hold up to 3 bar/800hp. I'm planning to run 12psi daily and 17psi max.
Dude, I don't know your financial status or your mechanical knowledge, but judging from your posts over the past, you need to pay someone to set your car up for you. There are a bunch of warnings set-up on this forum to prevent you guys from foolishly throwing away your money and not even having a "so-called" perfromance vehicle that's worth driving. I'll reitterate this from the sticky "Venting your BOV on a MAF-based system is bad"! I do it on my boosted Hyundai and it gets pissed at me and dump fuel like crazy, but I can't complain about it because I know better and I do it anyway.
Take the time to read and you'll see that there's a better way of going about things than the way you are doing it. If you guys who chose not to read the valuable information displayed on this very public forum, then your failure is your problem . I'm sure members don't mind helping you guys out, but I continue to see the same people with massive issues and though I can probably easily give a solution, but I prefer you newbies and guys who are new at this turbo thing, to do the leg-work and learn your objective.
Remember this guys/girls, there's no skating up-hill without putting forth some effort . And you all can take this for whatever it's worth.
Dee
