SERIES 2 RB25DET
Ok, so I have issues with anything above stock boost. I started with the Iridiums at first but that turned out to be too hot of a plug like I've read on here from other people with the same issue. I'll list what I've done:
New Copper plugs in the heat range suggested (colder) gapped to 0.8mmChecked every coil pack for damage (found none)Did a boost leak test up to 20lbs on FMIC (Tight as a drum)Checked vacuum lines (setup to best of my knowledge, BOV works,)Have Walboro 255 with stock FPR (plugs from before were pretty dark and gassy smelling)Searched numerous forums and threads but only read people had issues on part throttle.Checked fuel pressure at idle and it seems right, but I obviously can't check it at WOT because I have no access to a dyno.Here's pics and a video of my car at a small event to give you an idea of sound.
Now, just so you know this was done with colder range copper plugs and before I couldn't boost above 7lbs without hearing this noise and feeling power loss but now I can hit about 10lbs freely and anything above 12 gets the stutter at WOT and around the higher boost I have it set at.
Video:
http://www.youtube.com/watch?v=hDbU0cHx53Q
Modified by dekansnowman at 3:33 AM 3/2/2010
Modified by dekansnowman at 4:25 AM 3/2/2010
