Misfiring 3 & 5 idling up and down
Ampstunner
Car: 1991 Nissan 300zx twin turbo
1991 Nissan 300ZX Twin Turbo. I have deleted the A1V, the EGR, plenum, and carbon canister. I have also completed the prvr removal and bypass. I've added new injectors 555cc, new plugs gapped at .35 , new exhaust and a manual boost controller. The coils are good. The car is misfiring at 3 & 5 and idling up and down. Please help
centralcoaster33
Car: 1997 Nissan 240SX #5
Your CAS comes to mind, but I don't really know. Maybe look into that. You've already found the thread I was thinking of. There's more. Keep it up. Try the FSM while you're at it. Service Manuals link is on the top of each page here.
Welcome to NICO Club!
Ampstunner
put in a new computer from Z1 Motorsports it stopped the idling up and down and misfire on cylinder 3 measure the time I was on 15 degrees cylinder 5 still misfire getting fuel and Spark but don't know if the spark strong enough change coil packs around a spark plugs around still misfire on cylinder 5
centralcoaster33
You can check your ground wires I think. And your fuel injector. And the spark plug itself.
Ampstunner
put on a new PTU check and clean all wire connections check the injectors still misfire on cylinder 5
