bmadd2402 »
https://forums.nicoclub.com/bmadd2402-u23099.html
Sat Jun 23, 2007 10:56 am
I have a s1 rb25det, which is misfiring at wot, at about 5000 rpm under load. I swaped the wg actuator with a rb20 10psi WG. FMIC, Walbro 255l, 3in turbo back exhaust. I have Datascan, and all the sensors are within spec as far as I can tell, maybe the o2 sensor is a little off. the only thing that I saw is that the injector duty cycle was kinda high. 87.61 at 6650. also the air flow from the MAF was 4.94, also kinda high. I am only running 10 psi, so these shouldn't be that high should they? all the plugs are proerly gapped. I am getting a detonation code from the ecu, and it is pulling 5 degrees of timing at idle. I have great compression, and the plugs dont SHOW any signs of detonation. And then Timing. my cas is fully advanced, and I am still at 20* (with the light). I do have an exhaust leak, if that matters. so it is either maf, cas, fuel, ignition or timing.
Maybe someone could give me a place to start. I need to get the timing sorted out first, so why would the cas be fully advanced and still show 20 degrees of mechanical timing?
Anything I failed to mention just ask.
