Z32man »
https://forums.nicoclub.com/z32man-u164976.html
Wed Sep 08, 2010 9:07 am
Last week my car started to make the noise as if one of the spark plug wire went bad but while i was driving it went away. I changed all of the spark plugs and then everything was fine until this week. This week its back and i figured out that the number 1 and 2 cylinder ignition coils werent working. I replaced them with new ones but that did not fix anything. I used the number 4 cylinder coil wires for the new coil and it worked fine. I have no idea what the problem would be other than the wires? Im not sure what would cause just the number 1 and 2 cylinder wires not to work. The feeling is when im driving, my car shakes and has a weird sound to it. I thought it may be the injectors but idk if that would cause the coil wires not to work? The engine is fairly new with 50,000 miles on it.
