240z4u »
https://forums.nicoclub.com/240z4u-u26156.html
Sat Jun 03, 2006 4:54 pm
Thanks for the reply! It makes life easier when you have people to bounce scenarios off of. Here are your answers, and the picture attached is of my plugs that I pulled out, number one is on the far left.
[QUOTE=Bluefire]Ok you need to explain exactly what you modified on the motor prior to the misfire problem. As far as I can see all you did was change the injectors and then had a misfire problem. Now was the car running good for awhile after the injector change or did the misfire occur immediately after the injector install.
Modification.. changed out fuel rail to a top feed unit and installed 550cc injectors. I also had to change a few fittings on my FPR etc. so everything would work correctly. Nothing out of the ordinary there. My fuel pressure is rock solid at 42 base with line off, and the aeromotive FPR seems to be reacting fine to pressure/vac (this unit was on with the stockers too).
Also you can isolate the misfire by pulling the plugs on the coil packs one by one or injector plugs one by one. If you don't notice a change in the motor when you pull a plug that cylinder is the one that is not firing. Now swap that coilpack with another one and see if that cylinder is now misfiring. You can do the same with injectors.
I did pull plugs on the coils, and could not find a definitive problem cyl. My best job of narrowing it down put me at cyl number 3. The porcalin (sorry for the crap spelling) is more grey than the rest. I also dropped cylinders with the power FC injector map to try to isolate it.
IMO if this happened after you installed the injectors, there is 99% chance it is the injectors. And depending on the quality of the injectors, there might be a big difference in flow. One might be flooding a cylinder or just not flowing enough.
Yes this happened directly after the fuel injector installation, however the day before or something like that my car dropped a cylinder or two for fun after getting on boost. I am still skeptical that it may be coincedental. The guy who I got the fuel injectors from claimed that they were flow tested and matched. I am going to email him, he may be full of crap.
How did the spark plugs look, be specific. What percent are the injectors set to on the power fc... What else did you remove while changing the injectors...
I want to say the percentage on the power FC is like 72 percent, when I did the math it came out to 68 or something like that but my fuel maps were SOO far off I changed the correction percentage to get me in the range. I have no idea what the injector lag time is, but the car runs best with +.08 lag time dialed in.
I removed intake pipe from TB, coolant lines to TB, throttle cable, upper plenum, a couple emissions or whatever lines from the bottom of the plenum, and all the vac lines to the charcoal canister etc... I also unplugged the IAC solenoid connections, and the TPS connectors. Everything got hooked back up correctly, I triple checked, and also triple checked again today when I replaced the gasket between the halves.
Also the injectors all metered out at the same static resistance, and I had put different injector plugs on to accomidate the new injectors.
This is about all I can think of right now though! Ill give it some more thought and post again if I think of any other oddities.
Car idles and revs perfectly until underhood temps start to rise.
Evan
