silkysmoothyjud »
https://forums.nicoclub.com/silkysmoothyjud-u50966.html
Thu Jan 01, 2009 5:42 pm
Alright, I am having a similar prob, but I've been down this road before...Still trying to save some cash. I have replaced 4 injectors with OEM and I think I am gonna replace the remaining 4 with D-works injectors and just be done with it. Injectors 1 and 2 can be replaced without removing the plenum, so put iffy aftermarket old ones to the front strong ones in 5-8. I am soooo done, I am just gonna replace the other four and that will be the end of it. Keep a few spares around to fool with #s 1 and 2. Make sure you pull that fuel pump fuse while your Q is running and let it die before removing, unless you like rod knock/hydrolock...
