Misfire Problem Weird
Zeph240sx
Car: 240sx 1990
I' have been wondering about this. Recently i fixed a Intermitten misfire problem with the coilpacks on SR20. What i did was just swap from front to back and so are the middle coilpacks. That did it, but why would swapping them front to back would fix this problem? I understand if the coilpack is weak it will not ignite that good in anywhere you put it, but doing this method fixed the problem.
Any thoughts?
PapaSmurf2k3
Site Admin
Maybe re-installing the harnesses cleaned off the connectors just enough to kick up the power a bit, or you matched a weaker coil with a hotter cylinder or something, thus making it easier to combust.
:gotme
