Misfire Problem
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
craigztoyz
Car: lots of unique hot rods, and customs, with modern engines, and a good truck to pull the trailer.
Hey, Thanx for helping if you can.
I'm working on a 99 G20 (sr20de)
has a distributor, with new cap/rotor, plugs and wires.
I changed 2 of the injectors thinking that was part of it, seemed better for 1 mile, then its back to major misfire. Not as noticable in nuetral, but in gear, under load, it is bad.
Worse when you get higher in rpm.
Lookng for advice, and ideas.
experince with this problem is really what i am looking for.
thanx Craig
snwbrdr435
Car: 85 VW Westfalia, CBR F4i, SV650s, 1988 Honda Hawk(race)
Bump Friends having the same problem did you end up fixing it?
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
