fuco8210 »
https://forums.nicoclub.com/fuco8210-u66121.html
Tue Sep 04, 2007 8:35 am
Ok i swapped in a 93 ka24de into my 92, everything is fine but as of late it tends to misfire badly at idle and under low rpm at partial throttle. It runs fine and clear for the first minute on a cold start, then once warmed fully it starts to get really bad. I swapped distributers with a known working one; that didn't do it. So next i did plugs which were cheapo denso autozone plugs, gapped to .38; that didn't do it either. Next I did plug wires with the same outcome. Codes thrown are, 13, cts which i replaced and its still throwing the code; 14 vss? and 33 front o2.. None of these should be the cause of my problems though? Could it possibly be a bad/clogged cat? Or maybe the ignition coil? Any insight is appreciated.. Thanks!
