Drove to church and it drives seemingly okay but definitely misses when at lights, etc.
Should I change the plug one more time in like a week incase some of the sealer got to it?
Drive to church, almost 20 miles.
Understood. Never did a treatment like this before so not sure of when to expect results hah.VStar650CL wrote: ↑Sun Apr 05, 2026 9:41 amIt wouldn't hurt to change the plug. Give the sealer some time to work, each time you shut the car down it will try to clot any remaining opening. If it doesn't improve then maybe it's not a head gasket. I don't recall, did you ever try a new injector on #2?
Persistent P0302 & +25% STFT2 Post-Service - Diagnostic Data Included
Vehicle: 2016 Infiniti QX60 (148k miles)
Primary Symptoms:Recent Work Performed:
- Hard Cylinder 2 Misfire (counts climbing rapidly, ~1,000+ per session).
- Bank 2 Short Term Fuel Trim (STFT2) pegged at +25.00%.
- Bank 1 (Rear) STFT is stable at ~0% after clearing self-learn.
- Rough, surging idle (800–850 RPM).
- Misfire is present at idle; unplugging Cylinder 2 injector causes a noticeable idle drop, confirming the cylinder is partially contributing.
Diagnostic Steps Taken & Results:
- Drained/refilled coolant with Zerex Asian 50/50.
- Replaced VIAS Control Solenoid (original snapped during engine cover removal).
- Spark Plug replacement on Cylinder 2.
- Recent "BlueDevil" coolant stop-leak treatment (context for potential fouling).
- Note: Engine cover removal was "aggressive" due to a spinning brass insert.
The Conflict:
- Ignition: Swapped Coil #2 with Coil #4; misfire remained on Cylinder 2. Swapped new plug back to old plug; no change. Well is dry and clean.
- Fuel: Verified Cylinder 2 injector is pulsing (audible click). Unplugging/reseating injector connector (confirmed "click") did not resolve the +25% trim.
- Vacuum/Air:
- Checked VIAS solenoid routing and pinched hoses; no change in trims.
- Pinched EVAP purge line; no change.
- Checked intake snorkel/MAF seating; cleaned MAF.
- Performed brake cleaner "spray test" around plenum and Cylinder 2 intake runner; no surge detected.
- Confirmed one intake manifold dowel/bolt hole was "hissing"; sealing it with a bolt improved trim slightly, but Bank 2 remains pegged at +25%.- Software: Successfully completed Idle Air Volume Learning via CVTz50, but idle remains high due to fuel trim compensation.
- O2 Data: Bank 2 Sensor 1 (Wideband) shows erratic AFR swings from 12:1 to 26:1, frequently sticking Lean (High Voltage/Lambda), triggering the +25% dump.
Despite ruling out a dead coil and verifying injector pulse, the ECU sees a massive Lean condition on Bank 2. Unplugging the MAF causes both banks to jump to +25%, but after clearing, the fault remains localized to Bank 2.
Request for Insight:
Is it possible that the "aggressive" prying on the front engine cover bolt caused a localized internal plenum crack or a lower intake gasket breach at the #2 runner that isn't reacting to external spray tests? Also, could "BlueDevil" residue in the combustion chamber be poisoning the B2S1 O2 sensor to report a false lean?
Any advice on the next "precision" step would be appreciated.
Amazing. If you didn't have bad luck with this thing, you wouldn't have any.Ilya wrote: ↑Sat Apr 18, 2026 5:16 pmTwo steps forward, one step back.
New to me intake plenum arrived 2 days early. Required a ton of cleaning but anyway.
While taking the old plenum of out the car, I removed 3 of the 4 Throttle Body bolts and the 4th stripped. CRAP. I gave the old plenum to my neighbor who works in a shop; hope it doesn't cost me more than $20-30 bucks to do so. I ordered a lower mileage used one from eBay just in case that one gets damaged or can't be removed from the old plenum so may have to wait till Wednesday or Thursday to replace. However, I left some hoses and such on the old plenum and don't want to bother the neighbor so I wasn't able to install and prep the new plenum for the new throttle body...ugh.
Yes. The drainback valve won't keep a lot of pressure in the system, it mainly makes sure that what's in the rail is liquid and air can't creep in. If you put a pressure gauge on it, most Nissan drainbacks will fall to below 30 psi within a few minutes and then very slowly drop to near-zero from there.
Considering that it's a single-cylinder issue, I'd say the former is more likely than the latter. Your luck as a technician, as noted earlier, is a different matter.
I'm absolutely shocked at what I am accomplishing on this vehicle. I need to walk around with a warning sign that reads: will break anything.VStar650CL wrote: ↑Tue Apr 21, 2026 9:27 amDunno how you did that, but the studs are readily available from both Nissan and Infiniti. P/n 08246-63810.
Yeah, it's M6X1.0 but I decided to wait till tomorrow to get the real thing. I bought some but I'm afraid they aren't the right class of bolt to withstand the heat cycles, etc. and could lead to issues later. Wife will just have to be light on the throttle tomorrow lol.VStar650CL wrote: ↑Tue Apr 21, 2026 2:38 pmM6 x 1.0 sounds right, but use the thread gauge at Lowe's or Home Depot if you don't own a set. The stud doesn't have a lot of torque or tension on it, so you could even use regular threaded rod from the hardware section. Just cut it to length and double-nut the top to spin it in.
It sort of does, but I've never heard of a Nissan having an oscillating butterfly problem like those GM's. Yours is more regular, something spinning that's hitting something else. Like a collapsed lifter, except you didn't go near those. Have you put a steth on it to see where it's loudest?Ilya wrote: ↑Wed Apr 22, 2026 4:17 pmIt does actually sound like this, no?
https://www.youtube.com/watch?v=MM_QpWHZJgs
You're right, I didn't. But I imagine that broke when I removed the nut so would have fallen away before I removed the plenum no? I didn't hear any sounds of anything falling inside the ports and a stud would have made a metallic noise.VStar650CL wrote: ↑Wed Apr 22, 2026 4:34 pmUh-oh, wait a sec. You have a missing piece of stud. Did you ever find that?
