Hi, sorry to revive my demise, ... again.
Received the Coil Packs from Dee (thanks btw) with the exact same results.
By luck I found the following post, quoted from Nissansilvia.com, referring about SR20s but it seems to apply to my issue:
http://www.nissansilvia.com/fo...=2820
"The knock sensor on the SR20 can become faulty from now and them This is a condition where the engine runs perfectly cold, and then after a few minutes of hot running loses all power and borders on almost undriveable. It is not overly common but is capable of costing you a fair bit of diagnostic time. The only solution is to source either a 2nd hand unit frm a wreckers or to purchase a new sensor from the dealer."
What should I look for in regards the Knock Sensor? My ECU gives Code 55, but should I consider replacing it? Bypassing it with a resistor? Disconnecting it? I guess checking the plug and cleaning down there would be a good start, but just in case, what would be the Part Numbers of the bits involved?
As always, any input is welcomed.
