Yep, that was my next guess...kouki munster wrote:Check the injector o-rings.
I said MAF, not O2, but the more I think about it, the more it seems like a spark issue. Start double checking your connections.240dx wrote:would the o2 sensor cause it too run THAT rich??
Well then, lets talk about his fpr then, that would definitely cause a few of those symptoms...PyR0NiAk wrote:Could be fuel as well. And in this case seems more likely, considering he has good compression.
As usual you are wrong his car is turbo but dingusDattebayo wrote:White smoke means coolant.
Also, wtf do you need iridium for? Your car isn't turbo...
Completely slipped my mind, but yeah that would definitely do it. FPR may have failed. Would also explain why it was gradual.Dattebayo wrote:Well then, lets talk about his fpr then, that would definitely cause a few of those symptoms...PyR0NiAk wrote:Could be fuel as well. And in this case seems more likely, considering he has good compression.
Go hump a cactus.Lonismos14 wrote:As usual you are wrong his car is turbo but dingusDattebayo wrote:White smoke means coolant.
