zvinner »
https://forums.nicoclub.com/zvinner-u58686.html
Mon Mar 12, 2007 2:52 pm
I just overcame a miss myself in a '90 n/a. i used chevron techron to clean the fuel system. then i checked all the injectors, and when all else failed i cleaned the air filter and ignition module. I guess there was a factory recall and some of them didn't get replaced. The old one looks like an aluminum heat dissipator or something. I'd suggest you do the latter two before you tear into it any more.
also, sometimes the injectors can stick. If you tap on them (not too hard) with a screw driver and mallot they might get the crud knocked loose. i'd be really careful doing that one though.
