Empire087 »
https://forums.nicoclub.com/empire087-u194190.html
Mon Jun 10, 2013 9:40 pm
So i turbocharged my single cam last summer and its been pretty darn good at 7 psi, more than enough to put grins on the peoples faces i run and that ride with me.
Anyways Out of nowhere i got this missfire at idle, hesitation from a stop, and a misfire at wfo after reaching full boost. Ive noticed the misfire at idle only happens when the motor is fully up to operating temperature, when this first happened i replaced the wires, plugs, cap, and rotor. It temporarily went away, but about a week later the problem came back. This was also joined by the hesitation when slowly getting on the gas from a stop, its super annoying. Then there is the w/o misfire, its weird because it will rev out a little bit and then just miss and fall on its face, sometimes if you stay into it it will clear up, other times it just continues to bog. This only happens when the engine is good and warm, Ive noticed that it usually tends to start right after it gets past 167 degrees on the coolant temp. The annoying thing is im throwing no codes that pertain to the miss, and its not consistent in any way shape or form. I also have problems with it wanting to start once hot. Im a little dumbfounded, just not sure what it could be.
Thanks for the help!
Dakota
