Cameron »
https://forums.nicoclub.com/cameron-u67208.html
Thu Jan 31, 2008 6:15 pm
I know this Probably wont help you none, but i found out the problem on my KA. I was having similar problems, like when would gas it, whether it be at idle, or on a rev match on a down shift, air was getting into the Engine, but fuel was delayed, so it made my AFR go haywire, and it would pop, stutter, and go almost dead, until it realized that it needed fuel then it would rev up. When it first started happening, i thought up many scenarios. First I thought it was MAF Related, but then i realized that it wasnt, cause once it got past the fist couple thousand rpms, it revved up fine til redline. Then i thought i just got some bad gas or something. Then i filled up another tank and realized that wasnt the problem. Then i thought, well hey maybe it has to do with ignition! So i changed the Spark Plugs, Wires, and while i was changing them, i popped the Distributor cap off, and saw that the plug for the coil wire was roasted, and white powdery plastic everywhere. so i replaced the Cap, in hopes of it working. It Didnt Help.. Then I Replaced the Fuel Filter, took it for a test drive, and still no. So today i was all bummed, and started thinking that my baby was finally dying, and thought it was a Bad TPS, Bad Valve, because i have ran her hard lately, and i didnt want to admit to it, that its life was about to be over, so i blamed it on the weather , and even a vacuum leak. And today i was out piddling around with it, and was revving with the throttle Cable, and Noticed this little plug right here.
This plug for you:
This Plug for me:
it was wiggling around. So i pushed it down and held pressure on it, and revved it, and all of a sudden things cleared up. Pulled up on it a little bit, and things went back bad. So i Found the Problem, took it off, readjusted a little bit where it would stay plugged in. And now shes running fine and dandy, with a good $100 tune up. I knew the end of her life wasnt quite here yet!
So just for the sake of dumb luck, go out there and check that plug, wiggle it around and hold pressure on it, then rev it, see if it changes how its acting..
Cameron.
Sorry For the ThreadJack..
