On a side note this engine is thirsty for oil. I burn and add back about 2-3qts of oil every 6k. I use Mobil 1 High Mileage. I'm convinced this is poor piston rings since there are no leaks.
Now to my current problem....
Prior to all this major work we noticed some hard starts after a month or two of ownership. Occasionally it would take a few extra cranks to start. It slowly got worse and more common. Recently it has gotten a lot worse and we started getting a misfire on idle. Some starts it takes 3-5 second to start the engine. Once you give it any gas the misfire goes away and it runs well.
I've pulled P0301 twice now (cleared and it came back). I checked cyl one, tried a new coil and plug; nothing changed. Still getting random misfires upon idle. All is well once you give it gas and are driving.
My gut tells me this is a dirty or failing injector on cyl. I've been hesitant to diagnose more on my own or take it into the shop because I know getting the intake manifold off is a PITA (2-3 hours based on my last experience).
I just put a whole bottle of Techron in a full tank but the problem still persists, perhaps its slightly better. Next I'm going to try a bottle of good old Seafoam.
What are your thoughts? Do you agree this is likely an injector or could it be something else? What do you recommend for fuel injector cleaners?
Thanks!
