amencowboy »
https://forums.nicoclub.com/amencowboy-u250657.html
Thu May 07, 2015 10:34 am
Been busy but finally got some time to work on my s13.
Changed the front crankshaft seal (front main seal) because it leaked a small amount of oil onto the harmonic balancer which then flung the oil around the bottom half of the engine. This required removing the fan, shroud, belts, radiator, draining coolant, and unbolting harmonic balancer. It is possible to replace the front seal without removing the radiator, but doing so allows enough room to fit an impact gun on the harmonic balancer nut, plus I had no idea when the last time the coolant was changed and as easy as the radiator is to remove, I probably saved time by not having to wrestle with the harmonic balancer nut with a ratchet.
I removed the IACV which had a nice layer of carbon so I cleaned it. I did not expect this to fix my misfire problem but figured after 21 years it deserved a cleaning. Ordered a new gasket and bolted it back on.
To remove the IACV I pulled the top heater core hose off to gain a little more access (coolant was already drained from the system but the hose sits pretty high and you would probably only lose a small amount of coolant by pulling it off), then I unscrewed the long hexagonal solenoid FICD valve and unplugged it (blue connector). Then I unplugged the brown AAC solenoid and unbolted the four 10mm bolts holding the IACV unit to the engine. It is a tight squeeze, but I got a 1/4" ratchet in there on a few of the bolts but had to use a wrench to reach the rest. There is not much room between the engine and firewall and much wiggling and patience was needed to remove the IACV assembly. I used a pry bar to break the seal from the gasket and get it out from between the bracket that holds the metal tube and the intake manifold. Once free I cleaned with some carb cleaner, a small plastic bristle brush, and some cotton swaps.
The IACV gasket would have probably have been damaged if I tried to squeeze the IACV and gasket in at the same time so I made a note of how it would need to be positioned to line up correctly after I got the IACV in place
When replacing the IACV, I had a hard time getting the assembly between the bracket that holds the tube (which shares the bolt going through the top right corner of the IACV) and intake manifold. I had to pry the metal tube bracket away from the engine to make enough room to slide the IACV against the intake manifold, and then pry again to make enough of a gap to slide the new gasket into place. Aligned all the bolt holes and bolted everything back together and connected the heater core hose (this will cause a small air pocket if you did not drain the whole cooling system and will need to be removed by belching the air out somehow).
Installed a new coolant temperature sensor. When I was cleaning the mess that years of a leaky front crankshaft seal made I found the underside of the coolant temperature plug was coated in dirt and oil. Again, I do not think this was the absolute cause of my misfire, and I know I could have tested the old sensor to see if it was still reading the correct numbers at the specified temperatures, but for how cheap the part is and how important it is I decided to install a new one. No teflon tape on new threads, sensor I believe needs the contact with the metal to work correctly? Coolant sensors play a very important role in the PCM's management of an engine because it uses temperature as an input to many of the functions that the PCM handles. Slight defects in coolant temperature sensors can result in inaccurate numbers being sent to the PCM which can cause the PCM to deliver fuel and air in non-ideal quantities. Temperature is a parameters in the PCM's function to compute how much fuel and air to deliver at any given time. If off by a little, you may not even notice it, off by a lot and it throws the whole game off.
When I went to replace the plug wires I found that the wire between the cap and coil was stuck in the cap. It had corroded and was seized in place. I decided to buy a new rotor and cap. It is important to note that there are two distributor manufactures for the s13, Hitachi and Mitsubishi, and the caps and rotors are specific to both (the bolt holes are a few millimeters off between the two and will not fit the other manufacturer).
I found a large black spot on the air filter which puzzled me for while until I learned that the s13 has a small pump that is supposed to pump air into the exhaust manifold in the event it detects negative pressure. Nissan felt that this air needed to be filtered and connected a hose to the main air box which would feed into the exhaust manifold. This system is completely mundane and was taken out of the design of the s14. With the car running I pulled the hose going to the air box and found that instead of supplying clean air to the pump it was venting exhaust gases into the air box. Simple fix for the moment was to remove the black plastic cube and plug the hose going to the pump with a clamp and bolt. I plan to remove it completely in the future.
So after all of this the car runs a little better than before, misfire is not happening as often and goes away when the engine heats up. It bogs on acceleration at low rpms but comes back strong after about 2900 rpm. The car does run better and idles great when it is warmed up. The new cap and rotor helped clear up some firing issues but probably were not the only cause of the engine running rough and misfiring. Next plan is to change the MAF and see if that helps anything. I was getting the MAF code from the PCM but the engine is able to rev over the limit that limp mode restricts it from revving above and when the MAF is unplugged the engine idles lower and the misfire does not disappear.
